AWS Glue is a serverless ETL solution that helps organizations move data into enterprise-class data warehouses. It provides close integration with other AWS services, which appeals to businesses already invested significantly in AWS.  If you are looking for a replacement for AWS Glue, this guide will walk you through the top 5 AWS Glue alternatives. […]
