Today, AWS announces the general availability of full AWS Management Console experience for multi-container jobs in AWS Batch. The multi-container jobs feature makes it easier and faster for you to run simulations when testing complex systems like those used in autonomous vehicles and robotics. With the ability to run multiple containers in a job, you can benefit from the advanced scaling, scheduling, and cost optimization capabilities of AWS Batch without rebuilding your system into a complex monolithic container. Instead, you can use multiple smaller, modular containers that each represent different system components like a 3D virtual environment, robot perception sensors, or a data logging sidecar.
