MacRumors Posted January 18 Share Posted January 18 Pre-orders for the Apple Vision Pro begin tomorrow, and if you're planning to use the headset's lossless audio feature you'll need to be sure you have the AirPods Pro 2 with USB-C. Luckily, these earbuds are still at their lowest price of all time on Amazon at $189.00, down from $249.00. Note: MacRumors is an affiliate partner with Amazon. When you click a link and make a purchase, we may receive a small payment, which helps us keep the site running. The headlining feature update on this version of the AirPods Pro is the addition of the USB-C port, replacing the Lightning port. Additionally, they feature improved dust resistance and, when paired with the Apple Vision Pro, they support 20-bit 48kHz lossless audio. $60 OFFAirPods Pro 2 with USB-C for $189.00 Keep up with all of this week's best discounts on Apple products and related accessories in our dedicated Apple Deals roundup.Related Roundup: Apple DealsThis article, "Pre-Ordering the Apple Vision Pro? Get AirPods Pro 2 With USB-C for $189 to Add Lossless Audio" first appeared on MacRumors.comDiscuss this article in our forumsView the full article Quote Link to comment Share on other sites More sharing options...
