Fix: response_type ‘id_token’ is not enabled for the application (AADSTS700054)
When creating and configuring an Azure AD App Registration to use for authenticating a web application with Azure AD, it’s common to see the AADSTS700054: response_type 'id_token' is not enabled for the application error when the application attempts to authenticate the user. This error may or may not occur, depending on the configuration needed. To […]
The article Fix: response_type ‘id_token’ is not enabled for the application (AADSTS700054) appeared first on Build5Nines.
