Posted September 23, 20204 yr AWS Glue Studio is a new visual interface for AWS Glue that makes it easy for extract-transform-and-load (ETL) developers to author, run, and monitor AWS Glue ETL jobs. You can now use a simple visual interface to compose jobs that move and transform data and run them on AWS Glue. You can then use AWS Glue Studio’s job run dashboard to monitor ETL execution and ensure that your jobs are operating as intended. View the full article
