How To Split Large PST File Into Multiple Smaller Parts?
oliverjames
In case to split an oversized Outlook PST file the accurate solution for this process is Split Outlook PST Software which lets you split a PST file into numerous PST files and save the PST large file in small sizes. It is powerful software that gives users the ability to divide their PST files into many segments according to their needs. It accepts PST files of all sizes and allows users to divide them into chunks of any size. Users of Split Outlook PST software can preview the items before splitting them and choose which items should be included in each section. Users can also password-protect the divided PST files. You can separate PST files using the advanced utility's feature according to size, folder, and year. This application is compatible with all Mac and Windows OS versions. It is compatible with Microsoft Outlook versions 2003, 2007, 2008, 2010, 2012, and 2016. Download the trial version and the initial files without paying anything.
Link to comment
Share on other sites
  Only 75 emoji are allowed.
  • Create New...
