Devops.com Posted March 22, 2023 Share Posted March 22, 2023 Postman today made generally available a visual tool infused with artificial intelligence (AI) that makes it simpler to build software by invoking application programming interfaces (APIs) found on its network. Shamasis Bhattacharya, chief software architect for Postman API, said Postman Flows makes it possible to use a low-code tool to build software using tens of […] The post Postman Releases Tool for Building Apps Using APIs appeared first on DevOps.com. View the full article Quote Link to comment Share on other sites More sharing options...
