Tecmint Posted March 21, 2023 Share Posted March 21, 2023 The post How to Run Angular Apps Using Angular CLI and PM2 first appeared on Tecmint: Linux Howtos, Tutorials & Guides .Angular CLI is a command-line interface for the Angular framework, which is used to create, build and run your application locally while developing. It is designed to build and test an Angular project on The post How to Run Angular Apps Using Angular CLI and PM2 first appeared on Tecmint: Linux Howtos, Tutorials & Guides.View the full article Quote Link to comment Share on other sites More sharing options...
