AWS Posted December 9, 2020 Share Posted December 9, 2020 Amazon EMR on Amazon EKS provides a new deployment option for Amazon EMR that allows you to run Apache Spark on Amazon Elastic Kubernetes Service (Amazon EKS). If you already use Amazon EMR, you can now run Amazon EMR based applications with other types of applications on the same Amazon EKS cluster to improve resource utilization and simplify infrastructure management across multiple AWS Availability Zones. If you already run big data frameworks on Amazon EKS, you can now use Amazon EMR to automate provisioning and management, and run Apache Spark up to 3x faster. With this deployment option, you can focus on running analytics workloads while Amazon EMR on Amazon EKS builds, configures, and manages containers. View the full article Quote Link to comment Share on other sites More sharing options...
