HashiCorp Terraform is popular Infrastructure as Code (IaC) tool used to automate infrastructure deployments. Terraform is great for deploying Microsoft Azure resources like Azure IoT Hub and other related resources when building IoT solutions using Microsoft Azure. This article introduces you to HashiCorp Terraform, the basics of it’s workflow usage as an IaC deployment tool, […]
The article Deploy Azure IoT Hub using Terraform DevOps Infrastructure Automation appeared first on Build5Nines.
