HashiCorp Terraform is a popular tool for managing infrastructure as code (IaC). By defining your IaC using Terraform, you can use version control with your infrastructure configuration and also automate infrastructure deployment in a consistent and repeatable way. Azure DevOps Pipelines can be used to setup YAML pipelines to instrument the Terraform infrastructure deployments using […]
The article Deploy Terraform using Azure DevOps YAML Pipelines appeared first on Build5Nines.
