Azure Bicep has an inline If/Else conditional expression that can be used to conditionally provision an Azure Resource or even a full Azure Bicep Module. It’s not the same syntax as traditional If/Else statements used in may programming languages like C#, Java, or Python. However, it is really easy to use and will give you […]
The article Azure Bicep: If/Else Conditional Resource and Module Deployment appeared first on Build5Nines.
