Devops.com Posted October 19, 2022 Share Posted October 19, 2022 Multi-cloud environments can be a double-edged sword. On the one hand, there are clear benefits to using whatever cloud or tool is best for your particular needs, regardless of vendor – in theory. In practice, however, the more choices you have, the more complex and expensive your environment becomes. In fact, Andreessen Horowitz postulates that […] The post More Choices, More Problems: The Double-Edged Sword of Multi-Cloud appeared first on DevOps.com. View the full article Quote Link to comment Share on other sites More sharing options...
