AWS Posted August 11, 2022 Share Posted August 11, 2022 Amazon EventBridge now supports integrations with GitHub, Stripe, and Twilio via webhooks using Quicks Starts. You can subscribe to events from these SaaS applications and receive them on an Amazon EventBridge event bus for further processing. With Quick Starts, you can use AWS CloudFormation templates to create HTTP endpoints for your event bus that are configured with security best practices for GitHub, Stripe, and Twilio. You can configure your GitHub, Stripe, and Twilio webhooks from the respective accounts; simply select the types of events you want to send to the newly generated endpoint and begin securely receiving events on your event bus. View the full article Quote Link to comment Share on other sites More sharing options...
