Build5Nines Posted July 31, 2022 Share Posted July 31, 2022 One of the most difficult things in IT is naming things. The same goes for choosing the correct naming convention to use when naming cloud resources in Microsoft Azure. Sure, you can name things pretty much anything you want, but if you’re not careful you’ll end up with a jumbled mess of mismatched resource names […] The article Azure Resource Naming Conventions and Best Practices appeared first on Build5Nines. View the full article Quote Link to comment Share on other sites More sharing options...
