Terraform: If/Else Conditional Resource and Module Deployment
Build5Nines
 Share
Terraform has an inline If/Else conditional expression that enables you to set parameters and variables programmatically based on the condition being evaluated. The syntax of this “If/Then” or “If/Else” expression is similar to other programming languages where you have a condition to evaluate, then the result to return if either True or False are the […]
The article Terraform: If/Else Conditional Resource and Module Deployment appeared first on Build5Nines.
Link to comment
Share on other sites
  Only 75 emoji are allowed.
 Share
  • Create New...
