AWS Database Migration Service (DMS) Schema Conversion is a fully managed feature of DMS that automatically assesses and converts database schemas to formats compatible with AWS target database services. Today, we are excited to announce that Schema Conversion now supports conversions from IBM Db2 for z/OS to Amazon Relational Database Service (RDS) for Db2.
Using Schema Conversion, you can automatically convert database objects from your IBM Db2 for z/OS source to an Amazon RDS for Db2 target, including stored procedures, functions, views, and other database structures. This is especially valuable for mainframe migrations as it simplifies complex processes by resolving syntax differences and compatibility issues between environments. Schema Conversion also provides detailed assessment reports to help you plan and execute your migration effectively.
To learn more refer to using IBM Db2 z/OS as a source for AWS DMS Schema Conversion and using IBM Db2 for z/OS as a source for AWS DMS. For AWS DMS Schema Conversion regional availability, please refer to the AWS Region Table.
