Organizations that are interested in improving their development velocity that follow the principles of the twelve-factor app might find benefits in understanding how to realize those concepts on Amazon Web Services (AWS). In this post, I will help you correlate the twelve-factors app concepts as you architect solutions on AWS.
Twelve-factors
Let’s start with a quick recap of twelve-factors. The Twelve-Factor App was published in 2011 by Adam Wiggins as a collaboration between developers at Heroku. He published it at a time when developers were shifting from a paradigm of writing software-as-a-service (SaaS) applications in their own cloud environments to having the applications hosted on a cloud provider, such as AWS. Their intent was to provide “a broad set of conceptual solutions” for building applications that were portable and resilient. The principles centered around reducing the software lifecycle burden, including application introduction, maintenance and operations, through sunsetting. These principles were captured in the following 12 factors:
  1. Codebase
  2. Dependencies
  3. Config
  4. Backing services
  5. Build, release, run
  6. Processes
  7. Port binding
  8. Concurrency
  9. Disposability
  10. Development and production environment parity
  11. Logs
  12. Admin process
These principles are portable and resilient application best practices.
At AWS, we have the Well-Architected Framework to capture cloud and architecture best practices, which contains similar practices to twelve-factors. The Framework comes from years of AWS Solutions Architect collective experience of building solutions across business verticals and use cases. The results are architectures that support secure, high-performing, resilient, and cost-effective systems in the cloud. If you’re responsible for the underlying infrastructure or the application, the Framework helps you, the CTO, the architect, the developer, or operations team member, understand the benefits and trade-offs of decisions that have to be made.
A brief history of the AWS Well-Architected Framework
AWS published the first version of the Framework in 2012, and we released the AWS Well-Architected Framework whitepaper in 2015. Following the initial introduction, we added the Operational Excellence pillar in 2016 and released pillar-specific whitepapers and AWS Well-Architected Lenses in 2017. The following year, the AWS Well-Architected Tool was launched.
While twelve-factors focuses on application characteristics, the AWS Well-Architected Framework provides architectural guidance. When your architecture undergoes a Well-Architected review, you can meet the guidance for a twelve-factors application more easily. With some factors, the Framework helps the application developer delegate some responsibility from the application to the infrastructure. Both frameworks aim to help you deliver applications and services that are robust, scalable, and cloud centered. The AWS Well-Architected Framework helps you reinforce these mechanisms.
The six pillars of the AWS Well-Architected Framework
Let’s explore the six pillars of the AWS Well-Architected Framework, what each aims to achieve, and where the twelve-factors concepts intersect with AWS guidance.
The following figures shows the twelve factors and how they map to processes in AWS, which are described in this section.
1. Operational excellence
The operational excellence pillar helps you review your organization’s ability to support development and run workloads efficiently. You can use the topics in this pillar to evaluate how you operate your solutions. The pillar guides you through inspection of organizational structure, inspection of your mechanisms, and identification of obstacles and roadblocks that might slow your ability to innovate. The results include a feedback loop of continuous improvement for operating the infrastructure and solutions.
The factors you capture through operational excellence are codebase (I) and development and production environment parity (X). Codebase prescribes that there is exactly one codebase used to deploy everywhere, which echoes the purpose of reducing the operational burden of maintaining your software. The argument for a single code base is for consistency, traceability, and efficiency across a unified development lifecycle. The second factor is development and production environment parity, which encourages developers to create smaller but more frequent deployments. It also encourages developers to maintain parity not just of the core software, but also the backing services between environments. Parity of environments is conducive to smoother development and deployment processes. Additionally, this parity helps developers catch issues in a non-production environment more consistently.
AWS services that can help you achieve operational excellence are AWS CodeConnections, AWS CodePipeline, AWS CloudFormation, AWS Systems Manager, Amazon CloudWatch, AWS Config, AWS CloudTrail, Amazon EventBridge, AWS X-Ray, AWS Organizations, AWS Control Tower, AWS Trusted Advisor, AWS Service Catalog, AWS Proton, Amazon CodeGuru (Preview), AWS Lambda, Amazon Simple Queue Service (Amazon SQS), Amazon Simple Notification Service (Amazon SNS), and AWS StepFunctions
2. Security
The security pillar describes how to use AWS Cloud technologies to protect data, systems, and assets that improve your security posture. At AWS, we advocate the shared responsibility model, which applies to the security pillar. AWS is responsible for providing a secure environment for managing and operating your systems and solutions, but it is your responsibility to implement those best practices in the context of your requirements. The security pillar describes best practices such as reviewing how you manage identities for people and machines, which helps you store secrets securely.
The config (III) factor can be mapped to the security pillar, which advises you to store variables and items that depend upon the environment as environment variables. This allows you to move between deployments without having to update your code. Configuration settings such as database connection strings, API keys, credentials, and other sensitive information should be separated from the application code. At AWS, we provide services that can be used to securely meet this requirement, including AWS Secrets ManagerAWS Systems Manager Parameter Store, AWS Certificate Manager, and AWS Key Management Service (KMS).
AWS services that can help you achieve security are AWS Identity and Access Management (IAM), Amazon GuardDuty, AWS Shield, AWS Web Application Firewall (WAF), Amazon Inspector, AWS CloudHSM, Amazon Macie, AWS Security Hub, AWS Config, AWS CloudTrail, Amazon VPC (Virtual Private Cloud), AWS Direct Connect, Amazon Cognito, AWS Firewall Manager, AWS Network Firewall, and AWS IAM Access Analyzer.
3. Reliability
The reliability pillar encompasses the ability of a workload to perform its intended function correctly and consistently when it’s expected to. Reliability means that your architecture and systems:
  • Appropriately scale resources to meet demands
  • Mitigate disruptions caused by misconfiguration or transient network issues
  • Recover when disruptions do occur
Automation of scaling and recovery are best practices within the reliability pillar.
Because twelve-factors helps developers deliver a reliable application, multiple factors are categorized under the reliability pillar of the AWS Well-Architected Framework. Backing services (IV) explains that you should have flexibility for integrating services. This way, when your system experiences issues with availability, the application can replace the troubled service without code changes. You should choose the right resource that provides scalability while optimizing costs. Dependencies (III) describes that applications declare and isolate dependencies to become modular and self-contained. This speeds up recovery by simplifying the setup for handlers of the application code. Applications that adhere to the processes (VI) factor run as a collection of stateless processes to support scaling. This is equivalent to creating microservices that can scale up or down depending upon the workload or bring in additional instances when one fails. Disposability (IX) suggests that an application’s processes can be started and stopped rapidly, which makes the application resilient to failures and capable of being adapted to elastically scale.
AWS services that can help you achieve reliability are Amazon EC2 Auto Scaling, Elastic Load Balancing (ELB), Amazon RDS Multi-AZ, Amazon Simple Storage Service (Amazon S3), AWS CloudFormation, Amazon Route53, AWS Shield, AWS Backup, Amazon CloudWatch, AWS Systems Manager, AWS Global Accelerator, Amazon Aurora, AWS Lambda, Amazon DynamoDB, and AWS Transit Gateway.
4. Performance efficiency
The principles under the performance efficiency pillar focus on using computing resources to build architectures on AWS that efficiently deliver sustained performance as demand changes and technologies evolve. Topics in this pillar include simplifying the consumption of technologies that align with your goals, the ability to go global in minutes, and reducing the time and effort needed to deliver a service.
The concurrency (VIII) factor prioritizes management of processes, which should be stateless and allow for horizontal scaling, promoting performance efficiency. The backing services (IV) factor also falls under this category because it dictates flexibility in integration. This flexibility enables the application to maximize performance by using the right resource that meets scalability and performance requirements.
AWS services that can help you achieve performance efficiency are Amazon Elastic Compute Cloud (Amazon EC2), Amazon EC2 AutoScaling, Amazon Elastic Block Store (Amazon EBS), Amazon S3, Amazon Aurora, Amazon DynamoDB, Amazon ElastiCache, Amazon CloudFront,Application Auto ScalingElastic Load Balancing (ELB), AWS Lambda, Amazon API GatewayAWS Step Functions, Amazon SQS, Amazon Kinesis, AWS Global Accelerator, Amazon Aurora, AWS X-Ray, Amazon CloudWatch, and AWS Compute Optimizer.
5. Cost optimization
The cost optimization pillar provides guidance for the architecture’s ability to operate systems and deliver the business value at the lowest price point. The cost optimization reviews help you avoid unnecessary costs, analyze and attribute expenditure, and use appropriate pricing models.
The relationship of the build, release, run (V) factor advocates for the process separation and strict discipline around efficient handling of application deployments. This aligns to the cost optimization pillar because cost effective operations are typically a result of well-designed processes and mechanisms. AWS services that can support the build, release, run factor are, AWS CodeBuild and AWS CodeDeploy.
Other AWS services that can help you with cost optimization are AWS Cost Explorer, AWS Budgets, AWS Data Exports, AWS Trusted Advisor, AWS Compute Optimizer, EC2 Spot Instances, AWS Savings Plans, Amazon S3 Intelligent-Tiering, AWS Lambda, Amazon Aurora, Application Auto Scaling, AWS Organizations, AWS Resource Groups, Tag Editor, AWS Marketplace, AWS License Manager, AWS Glue, and Amazon Athena.
6. Sustainability
The sustainability pillar focuses on minimizing the environmental impact of running workloads in the cloud. Topics in this include reviewing the lifecycle of your data and retention policies as a methodology to use only what is needed.
The disposability (IX) factor is aligned to sustainability because it highlights an application’s ability to rapidly start and shut down at a moment’s notice. This provides agility and optimized use of resources during the life of the application.
AWS services that can help you achieve sustainability are AWS Customer Carbon Footprint ToolAmazon EC2 AutoScalingAWS Lambda, Amazon EC2 Spot Instances, Amazon EBS gp3 volumes, Amazon S3 Intelligent-Tiering, Amazon S3 Lifecycle configurations, AWS Graviton processors, Amazon Aurora Serverless, Amazon RDS Multi-AZ deployments, AWS Compute Optimizer, AWS Well Architected Tool, and Amazon CloudWatch.
Remaining factors
Port binding, logs, and admin processes aren’t specifically categorized into the pillars of the AWS Well-Architected Framework. However, these factors can be addressed as an essential part of the services that AWS delivers.
The seventh factor: Port binding
The port binding factor says that an application should be bound to a specific port when it’s hosted as a web application with the intention of making the application completely self-contained. In the context of AWS, we offer you different ways to achieve this principle, which are dependent upon the way your application is deployed on AWS. When implementing port binding on AWS, we offer features such as security, service discovery, and dynamic port mapping to simplify and secure your applications through services like Amazon EC2, Amazon Elastic Container Service (Amazon ECS), Amazon Elastic Kubernetes Service (Amazon EKS), AWS Elastic Beanstalk, AWS App Runner.
The eleventh factor: Logs
The logs factor dictates that an application should treat its running process as an event stream out to files that are managed completely by the execution environment. AWS offers many types of logging to capture different aspects of your application and the supporting infrastructure. CloudWatch is a centralized logging management service that monitors, stores, and provides access to log files from AWS services. For more detail, see AWS services for logging and monitoring.
The twelfth factor: Admin processes
The admin processes factor advises application developers to perform administrative tasks in an isolated manner to minimize the impact on the main application. At AWS, this factor is realized as a separation of the control plane and the data plane. The control plane is responsible for managing, configuring, and controlling the network or system infrastructure, while the data plane is responsible for the handling the actual user data or traffic. This separation is an inherent part of AWS services. We believe this separation allows AWS to deliver services that are scalable, highly available, secure, and efficient.
Applying the AWS Well-Architected Framework
The Framework shouldn’t be treated as a checklist that you review after development is complete. Instead, a review should be explored during the design phase to help you learn and apply architectural best practices. By the end of development, architects should have built a solution that facilitates faster, lower-risk service building and deployment. The Framework is not a static document, and as AWS evolves, architects continue to learn from working with customers and refine the definition of well-architected.
If you are familiar with twelve-factors or want to develop a twelve-factors app on AWS, read more about the AWS Well-Architected Framework. Consider starting a review project on your own to explore the detailed questions underneath each category or if you have specific workload that you’re already working on. You can use one of the many AWS Well-Architected Tool lenses to focus on applying these best practices to the services that you’re using. To get started on a lens review, see AWS Well-Architected Tool, which is accessible at no charge through the AWS Management Console.
About the author
