Linux Tutorials: How to Append a Line After a String in a File Using sed Command
The post How to Append a Line After a String in a File Using sed Command first appeared on Tecmint: Linux Howtos, Tutorials & Guides .
If you’re working with text files on a Linux system, you may need to modify the contents of those files.
The post How to Append a Line After a String in a File Using sed Command first appeared on Tecmint: Linux Howtos, Tutorials & Guides.
