Posted June 14, 2024Jun 14 Schema management is crucial for ensuring data quality and consistency in a database. One prominent feature it enables is version control and change management. Version control helps maintain the history of schema versions, allowing an efficient way to track the changes made to the schema. To achieve this, you can use Schemachange, an open-source change […]View the full article
