Posted May 1, 20241 yr They try function in HashiCorp Terraform allows values to be read from a Data Source, input variables, or some other attribute while providing a default value if the evaluation expression errors. This is particularly useful when data is retrieved from an external system in JSON or YAML format and then decoded. The decoded result may […] The article Terraform: Conditional If Variable Does Not Exist (try function) appeared first on Build5Nines. View the full article
