The post How to Fix “-bash: sudo: command not found” in Linux first appeared on Tecmint: Linux Howtos, Tutorials & Guides .
Have you ever tried to run a Linux command using sudo only to see the warning “sudo command not found” splashed on your terminal? This can be quite frustrating and it prevents you from
The post How to Fix “-bash: sudo: command not found” in Linux first appeared on Tecmint: Linux Howtos, Tutorials & Guides.
