Posted March 23, 20232 yr The Hugging Face Hub is a platform that enables collaborative open source machine learning (ML). The hub works as a central place where users can explore, experiment, collaborate, and build technology with machine learning. On the hub, you can find more than 140,000 models, 50,000 ML apps (called Spaces), and 20,000 datasets shared by the community.Using Spaces makes it easy to create and deploy ML-powered applications and demos in minutes. Recently, the Hugging Face team added support for Docker Spaces, enabling users to create any custom app they want by simply writing a Dockerfile...View the full article
