Posted November 11, 20204 yr When working with Kubernetes (K8s) using a kubectl proxy, or even in Azure with the az aks browse command using Azure Kubernetes Service (AKS). There are times when mysterious errors can begin to show when attempting to access and use the Kubernetes Dashboard (kubernetes-dashboard) web application. Depending on where you see the errors they could […] The article Fix Kubernetes Dashboard Strange 401 Unauthorized, 503 Service Unavailable Errors appeared first on Build5Nines. View the full article
