Posted 6 hours ago6 hr Today, AWS Control Tower introduces a new ‘Enabled controls’ page, helping customers track, filter, and manage their enabled controls across their AWS Control Tower organization. This enhancement significantly improves visibility and streamlines the management of your AWS Control Tower controls, saving valuable time and reducing the complexity of managing enabled controls. For organizations managing hundreds or thousands of AWS accounts, this feature provides a centralized view of control coverage, making it easier to maintain consistent governance at scale. Previously, to assess the enabled controls coverage, you had to navigate to the organizational unit (OU) or account details page in the console to track the controls deployed per target. With this release, the Enabled controls view centralizes all the enabled controls across your AWS Control Tower environment, giving you a single, unified location to track, filter, and manage enabled controls. With this new feature, you can now more easily identify gaps in your control coverage. For instance, you can quickly search and filter for all enabled preventive controls and verify if they're applied consistently across critical OUs. You can drill down by organizational units, behavior, severity and implementation to see exactly which controls are enabled, giving you a targeted visibility into your governance posture across your environment. Lastly, you can also get a pre-filtered list of enabled controls by behavior from the AWS Control Tower dashboard’s Controls summary page. To benefit from the new Enabled controls view page, navigate to the Controls section in your AWS Control Tower console. To learn more, visit the AWS Control Tower homepage or see the AWS Control Tower User Guide. For a full list of AWS Regions where AWS Control Tower is available, see the AWS Region Table.View the full article
