Posted April 18Apr 18 AWS Security Token Service (AWS STS) now automatically serves all requests to the global endpoint (sts.amazonaws.com) in the same AWS Region as your deployed workloads, enhancing resiliency and performance. Previously, all requests to the STS global endpoint were served from the US East (N. Virginia) Region. With this enhancement, your applications benefit from improved latency and fault isolation as requests are processed in the same Region as your workloads. For example, if your application runs in US West (Oregon) and calls the STS global endpoint, your requests are now served locally in US West (Oregon) instead of being routed to US East (N. Virginia). This update is available in all AWS Regions that are enabled by default. No action is required from customers to benefit from these improvements. Any requests to the STS global endpoint from Regions not enabled by default (i.e. opt-in Regions) will continue to be served in US East (N. Virginia). We continue to recommend that you use the appropriate STS Regional endpoints whenever possible. For more information about these changes, see AWS STS global endpoint changes , and the announcement blogpost. View the full article
