Posted April 1Apr 1 What is Docker Bake?Docker Bake is a powerful utility introduced by Docker as part of the docker buildx plugin. Inspired by tools like make and docker-compose, Docker Bake lets you define and run multiple Docker builds in parallel using a single configuration file (docker-bake.hcl or docker-bake.json).If you're managing multiple Docker images, especially in a microservices setup, Docker Bake simplifies your build process dramatically...View the full article
